1 reading
#14,051 ·
Put the bike entirely back together. New front end including steering head bearings, and some miscellaneous parts around the bike. Took it for its first ride in 4 weeks, and noticed some issues :( The front wheel is bent slightly, and makes a noticeable vibration at speed. No idea what I'm going to do about that besides buy a new one.
#14,061 ·
Finished exploring the numbers for all possible cam arrangements from all versions of the 650 engine. All except any arrangement using SFV cams. I can't find the opening/closing angles anywhere. Anyone got them? If I ever fill all the missing data I plan on making a tech post with image overlays of the valve timing. At least, for the arrangements that shouldn't cause bent valves.
#14,062 ·
The two members using Pinky and the Brain references, you guys are awesome!
As for me, I rolled over 43k on my odometer bringing my total for the season so far to about 13.5k and about 26k total since I bought it last June. Started thinking about what i'd replace it with when I wear this bike out and realized I should be able to pick up another one for a song when/if that ever happens.
#14,066 ·
Phase 1 Complete. Just waiting on the Flyscreen and mount to get here to finish her up.
I also replaced about a dozen butt connectors with solder and shrink tubing. As much as the previous owner knew mechanically, he either isn't nearly as electrically inclined, or just didn't care. I think I'm about to start looking for an unmolested wiring harness and start over. Works out ok for me though I guess, I'd much rather be doing this than having to deal with mechanical issues.
#14,083 ·
Changed oil, cleaned and flossed the chain, lubed the chain, gave her a bath, and added reflective blue rim tape around the lower edge of the tank. Pictures of that later...
#14,085 ·
If you cover the tires in plastic wrap, they will off-gas less and be less exposed to ionization, and thereby be stickier next season...
Here's a shot of my bike with the new reflective stripe around the tank...
