Hi guys,
I sprayed carb cleaner on the carb rubbers today while the bike was idling and I'm confused by the results.
I read that if there's a vacuum leak, the revs should increase on the bike while I spray the cleaner on the rubbers.
Well, a completley different thing happened to me today. While I was spraying the cleaner on the rear cylinder/carb rubbers the bike dropped revs and then picked them up again after few seconds.
When I sprayed the carb cleaner on the front cylinder/carb rubbers, the bike shut off completley 3 times I tried this.
Is this a vacuum leak?
I will take my carbs out today and will try to fix this - any suggestions?
Thanks!
Thanks!
