SV 650 LED flasher relay
737 views 5 replies 5 participants last post by  GuilderlandGreg
Anyone have experience with LED flashers working together with OEM blinkers. My question is if it is possible to use both the OEM and LED with a relay/resistor? :eek:ccasion14:
#2 ·
With mixed types of blinkers you have two choices,
a resistor on the LED bulbs and old school flasher,
or solid state flasher that does not care about resistance.
The only downside to the solid state flasher is that it
will not make a burned out bulb obvious by not working properly.
#6 ·
Just went through this last month. First relay broke after two weeks. (A part supported only by its own electrical leads broke off). The second really I took the outer plastic case off and mostly filled it the relay's innards with glue gun glue to prevent it from happening again.
Still working...
