No blinkers etc.....
692 views 1 reply 2 participants last post by  jbswear
Ok I dumped my bike racing at Hallett 3 months ago, broke my leg, ankle yada yada yada....
Just getting back to where I can ride and all the sudden I have no signal lights on the dash or front or back. The headlight and taillamp are on but no brake light either.
I have a CA taillight with integrated signals and LED front signals. They worked before.....the wreck. Manual says the 30amp fuse controls most of these but if it was bad i would get no electrical, right? I have checked all connections and 10 amp fuses, im at a loss.....did not swap out the 30 amp yet due to spare but I get everthing else, so I dont think the 30 amp is bad...suggestions?
#2 ·
True. If that fuse went out, all would die. Whole bike wouldn't run.
If the other fuses are good, then you have a bad connection somewhere. Just gonna have to start tracing. Start from the battery to the fuse box. If those are all good, then start checking from the fuse box connections to the lights themselves.
Time consuming, yes. But it's the only way to go.
