*CURRENT*
_________
APRIL 2008 SV of the Month Winner! Thank you! http://forum.svrider.com/showpost.php?p=1004654&postcount=4
______________________________________________________________________________________________________
Received in the mail yesterday. I havent even installed them yet, but in the spirit of mod posts with no pictures or explanations I thought I would start the thread.
http://www.techspec-usa.com/products/gs_suzuki.html
Ok, after a few days of finagleing with my digital camera and Photobucket I have the pictures and a short write up. Firstly, I ordered the 'High Fusion' set simply becasue the 'Snake Skin' style were on Backorder and I am impatient. As discussed elsewhere I went with TechSpec as they are a site sponsor, the items seemed reasonably priced, and the StompGrips (I have read) may be difficult to install/remove and may not be comfortable if you arent wearing leather pants/suit - again, this is just what I read here and elsewhere...Your results may vary!
The TechSpecs were delivered in about a week and are dead simple. Some rubber pieces with adhesive. 'High Fusion' is like a lightly textured rubber mat, I reckon the 'Snake Skin' may have a little more texture to it. The StompBGrips seem to have a good amount of knobblyness (little rubber buttons that protrude) and possibly wouldnt be comfortable for casual riding or for casual clothes riding that is.
Make sure the surface you are mounting to is clean and dry, and has some heat in it - either sit the bike in the sun or use a hair dryer or heat gun. Remember this is your fuel tank so be careful with the heat! Firstly I removed a strip of the backing from each TS pad so that I could mock up placement and position where I wanted them. Then using a graphics applicator 'squeegie' I started working out from the center while peeling the backing away. You can crease the TS pad so go slow. I was able to move the TS pad around once or twice when the placement didnt seem right or if I had left a bubble or a crease. Once applied on the warmed painted tank I gave the TS pad some more heat and applied firm pressure to help the adhesive bond. NOTE - You CAN melt the TS pad! Yes, in a moment of not paying attention I left the heat gun in one spot for a bit too long and it started to smoke and melt....since it wasnt applied all the way for some reason I tried to grab the edge of it and subsequently put my fingerprint right into the melted rubber/compound! Adds character I suppose, it isnt really noticable anyways, just use caution.
Riding on the SV with them shows that they do work. Hard braking I can easily squueze the tank and not slide forward in jeans. Hanging off I wouldnt say that it was an epiphany, but you do notice they are there - it isnt like super glue holding you in one spot, but it isnt as freely sliding as it was prior without them installed. Worth it? Sure, I like the added control and they were reasonable to buy and install, removal (I did remove one whole TS pad to reposition) left the paint in perfect condition and the adhesive still good. A true test would be to see how they come off after use, but I am not ready to do that yet.
Cheers, and thanks for waiting for the write up!
V9
Graphics applicator squeegie, XActo knife, and center strip of backer cut out to ease positioning
Dont get that heat gun too close dummy!
Finished install
Gratuitous photowhore of my AceCafe sticker
A special Thank You to everyone who voted for my SV to be SVotM this month! Cheers!
2006 SV650 K6 "Cafe Fighter"
-Front Galfer SS Superbike braided lines
-2005 GSXR750 Front Radial Mastercylinder
-2005 GSXR750 Front Dampers, Triples, Wheel, Radial Brake Assemblies
-LSL Offset Match Clip-Ons
-PP Tuning Preload Adjusters
-GI Pro ATRE
-Rear Galfer SS braided line
-HRC Rear Master Cylinder Reservoir Delete Kit
-CRG shorty levers
-TechSpec High Fusion Tank Grips
-De-Flyscreened
-Harley Davidson VRod Headlamp with custom harness
-R6 Throttle Tube mod
-SV1K Snorkel mod
-14t Afam Front Sprocket
-Sargent Seat
-EvoTech FE
-Ohlins 46PRCL rear damper
-Kawasaki ZX6/636 Turn Signals on Aztec8 headlamp bracketry
-GP Shift
-Frame and Swingarm Motosliders
-CRG Hindsight Mirror, Renthal Bar Ends, Renthal soft street grips
-Suzuki Accessory Seat Cowl, CF Tank Pad
-Suzuki Accessory Radiator Side Covers, Krylon semi flat black
-Woodcraft Rearsets
-Leo Vince Full System (originally High Mount) with Low-mount Slip On Mid Pipe and Oval Alu Canister, M4 Race Mount Bracket
-Michelin Pilot Powers, 33psi front/36psi rear
-Tapeworks Gold Reflective Rim Stripes
-Hotbodies 2007 GSXR750 Carbon Fiber Front Fender
-Modified Battery Box with Tool Kit Area Removed
-Modified OEM Suzuki Rear Wheel Hugger
-Sato Racing Quick Release Tank Pin Set
-Fiamm Freeway Blaster horn
-Silkolene Pro 4
-Safety Wired Oil
Mod Session 8.0: http://forum.svrider.com/showthread.php?t=64352
Mod Session 7.0: http://forum.svrider.com/showthread.php?t=61311
Mod Session 6.0: http://forum.svrider.com/showthread.php?t=58007
Mod Session 5.0: http://forum.svrider.com/showthread.php?t=61022
Mod Session 4.0: http://forum.svrider.com/showthread.php?t=51068
Mod Session 3.0: http://forum.svrider.com/index.php?t...586#msg1076586
Mod Session 2.0: http://forum.svrider.com/index.php?t...646#msg1052646
Mod Session 1.0: http://forum.svrider.com/index.php?t...257#msg1034257
Mod Session .095: http://forum.svrider.com/index.php?t...1177#msg961177
Mod Session .07, .08, & .09: http://forum.svrider.com/index.php?topic=76849.0
Mod Session .06: http://forum.svrider.com/index.php?topic=70658.0
Mod Session .05: http://forum.svrider.com/index.php?topic=69725.0
Mod Session .04, .03, .02, & .01: http://forum.svrider.com/index.php?topic=69432.0
_________
V9
Finished install
-GI Pro ATRE
-CRG shorty levers
-De-Flyscreened
-SV1K Snorkel mod
-Sargent Seat
-EvoTech FE
-GP Shift
-Woodcraft Rearsets
-Silkolene Pro 4
-Safety Wired Oil
