I've had my SV650 for 3 years and 15,000 miles now...time to replace the battery?
1.5K views 16 replies 12 participants last post by  pothiawala786
#1 · (Edited)
I'm still using the original battery. I checked it last night and it says 12.4 Volts but I had topped it off earlier with my battery tender.
I rode it to work today so I'm going to check it again tonight. No other issues at all with the bike though.
Edit-Checked the battery tonight and it read 12.8 volts at rest and 12.08 with the ignition turned on but the bike not running. I think I'm good...no need to replace the battery at this time.
#3 ·
Unless you're made of money, keep using your battery tender, and ride it until it no longer cranks or holds a charge.
#7 ·
Personally, I'd rather not wait until I'm stuck on the side of the road. I use the battery tender about once a month and it typically only takes about 10-15 minutes before the light is solid green. I also ride the bike once a week at least, usually 2-3 times a week all year long.
I'll see what the voltage is tonight after my ride home and measure it with the lights on but engine not running as well.
#4 ·
Back in the bad ol' days when men were men and motorcycles came with wet cell batteries, 3 years was about the expected lifetime. The sealed battery in your SV should give 5 years of service easily, and more like 7 to 10 years typically (if well cared for).
#13 ·
A weak battery can start the bike yet die mid-ride. It happened on my DRZsm like this: Sat in the garage for about a month, no tender. Took a few tries to start. 4 miles and a few lights down the surface street came upon a road closure due to an accident, sat thru a couple light cycles with the brake on. At the next intersection signaled to turn (no brake as I remembered), and the bike died mid-turn. Cranked weakly initially but would not started. Eventually my wife came and gave me a jump from the car. The bike started right up and has had no problem since. I think idling at the light with the brake light on drained the weak battery too much. When I signaled to turn one block later it drained the battery below the threshold.
I have no battery tender. If I ride a bike once every 2 weeks I don't worry about its battery. When it sits for 4 weeks I start worrying about the battery.
BTW my '07 SV w/ 13k mi is still on its original battery.
#15 ·
Update: I checked the battery tonight and it read 12.8 volts at rest and 12.08 with the ignition turned on but the bike not running. I think I'm good...no need to replace the battery at this time.
#17 ·
21k on my 05 and I was thinking I had to replace the battery before this season. Checked it several times before the season and I should be ok. PO and myself have kept it on a tender when not in use pretty well, so its held up.
Maybe next winter.
