Jim's Speedo Conversion
Newton's Speedo Conversion preview
Jim's speedo conversion is very nice and does the trick. THe sensor selected is rugged and sensitive enough to pick up a pretty small magnetic field.
However, I found a couple things about it, that for my purposes, needed some changes.
1) I don't like the big sensor
2) or the big magnets and their mounting location
3) You can only tell the sensor is working while mounted with a meter or spinning the wheel.
To make it fit my needs a little better, I picked a different sensor. Almost anything that will operate within your electrical system peak voltages and sources a digital signal should suffice.
SENSOR SELECTION
Comtronics limit sensors. I don't feel like running out and getting the model right now. They are made for pneumatic piston/machine part limit sensing in industrial applications. Plenty tough.
They are smaller and more sensitive, and have a built-in LED so you know it's active. This allowed me to place it farther from magnets (or use smaller ones), and hide it behind the fender. Also, since I have 3 of them, I got a couple spares on hand just in case.
On the down side, they are not intended for automotive use, so are not totally sealed and probably not rated to auto grade. I brushed them with a little enamel paint, should be OK.
SIZE COMPARE
As you can see, the new one is considerably smaller, and that is after I totally shaved down the other sensor.
ON/OFF STATE DETECT
Easy-peasy; green light off, green light on. Note the much smaller magnets.
MAGNET PLACEMENT
Because they are small, I decided to mount the magnets IN the rotor. An added benefit: because they are closer to the axle, they have a greater included angle in terms of wheel rotation = longer detection time per magnet width). Not shown, but I measured out the magnets to fall directly under one of the fender mounting bolts as the rotor turned. The are spaced on every other arm - 4 magnets evenly spaced.
Here I am cutting holes to sink them into the rotor - milling bit in the drill press. A real drill bit will make the bottom of the hole conical, so don't do that. I made them stick out just a hair: flush would be good too, but I figured a little edge might help me dig them out later.
A BIT OF ADVICE
Get that old loctite out of there. Dressing threads is sometimes a good idea anyway.
I think everyone should see this. ;D
ROTOR BACK ON THE BIKE - MAGNET POSITION
The magnet hole is about to pass just behind that fender mount. THe sensor will hang from a mount on the other side of the fender, hidden from view.
MAGNET ATTACH
2-part epoxy the 4 magnets around rotor, and clamp down until cured. They are almost, but not quite, flush with the rotor. Binder clips are great for this kind of thing.
CONCEALING EVIDENCE OF THE CRIME
Hide the magnets with some black nail polish. I love that stuff - I always keep some in the toolbox. That may be a crime in and of itself.
Hide the wire behind the brake lines. Clamp on the lower triple and cable tie on the brake line itself keeps the wire tidy and out of view.
HELP OFFERED FROM NEIGHBOUR
Appreciated, but without opposable thumbs, you'll just get in the way. Come back for dinner.
SENSOR SELECTION
SIZE COMPARE
ON/OFF STATE DETECT
MAGNET PLACEMENT
A BIT OF ADVICE
MAGNET ATTACH
