541 - 560 of 1,056 Posts
Ok, so I'm going to apologize in advance bc A) this is prob a dumb question, and B) bc I'm not sure where to post but this thread seemed appropriate having to do with front end swaps.
I have the 06 750 forks (black with the chrome-ish tubes), an 08 wheel and rotors, and 04/05 calipers (the gold tokicos). I looked at the chart to see which size spacers would be needed (9mm) according to the OP, and then spoke with Zoran from TWF and his sizing chart was different (said 10mm spacers). I still have the spacers, but they're a bit big. The calipers are too high and the way they sit the pads are sticking out over the top of the rotors.
My question is, I've seen a few guys post pics of their front end swaps and they've used washers as a way to space the calipers incrementally until they sit where they need to be seated. Is that an acceptable way to space a caliper for track day use? Road bikes seem to be ok, but I'm wondering if the washers would be a problem with tech inspectors or if it's okie doke...
Right now the pads are above the rotors by about a 1/4 inch. Idk if that's a large enough to really worry, but I can just see myself running the front brakes so much that the pads wear down and then they hit each other at the top and no longer squeeze the rotor. And then I panic and hit the back brake, lock up the rear wheel and slide, start crying, and promptly soil myself.
I really don't want to have to explain that to a track day EMT. And have a weird nickname lol
Wheel/Rotors from an '08 600, forks from an 06 750, 05 600 calipers
10mm spacer from TWF
Pic of the caliper mounted, I left the rear spacer out for D'Ecosse since he mentioned the bushings in the forks... The front spacer is attached and sitting kooky. Soooo is that the problem? The little bushings sticking out from the forks have to come out and the spacers from TWF take up the old hole? ???
So If i read this thread correctly ( until page 25 lazy reader:icon_biggrin:) I should not have a problem with putting a 2008-2009 GSXR750 front end on my 2003 sv1000?
I just got a hold of 2008 -2009 gsxr 750 front end (everything but the wheel)for a great deal on it with only 3000 miles on it. I guess my question is there anithing I need to be aware of other than the ignigtion key?
I have a question about the wheel matrix on page 1, if I have k7 GSXR750 forks and axle, can I use newer/older wheels? k1+ GSXR600/750 and GSXR1000.
I wasn't sure what the bore is for on that matrix chart, is that the size of the axle hole?
The wheels are comparable fitment for all 01+ GSXR;
however the axles change with the fork generations;
Does that mean I need to change my axle bolt to match the year of the wheel? or do I keep my axle bolt matched to the year of my forks and I can just use any wheel as long as the rotor matches the wheel?
Thanks
