I have a 2006 SVS with the original battery. I left the parking lights on for about 4 hours yesterday. Bike started up fine immediately after, and I rode it about 75 miles right after that. The bike also started successfully about 4 more times after that for shorter trips this morning.
Then tonight i turn the key to on, the fuel pump engages, the headlights light up, but I would get only a pop noise when i pressed the start button (like perhaps the starter was engaging but not strong enough to turn the motor). After doing this several times, eventually I would get no lights whatsoever, and the pop noise stopped happening. Battery dead? Bad alternator?
And another thing: I bring the battery inside to place on a trickle charger overnight to see if that helps. After about 5 minutes on the charger, and about every 3 minutes thereafter, i get a loud squeal from the battery. It sounds as though its venting gas. It lasts about 2 seconds, and goes from louder to quieter. I've had this thing on the same trickle charger during the past two winters and I've never heard this before. I took the battery off the charger for fear it was about to explode or something. Any idea whats going on here?
Thanks in advance.
Thanks in advance.
