I'm hoping someone has some insight on this.
I bought a 2003 Suzuki SV650s this past Friday. The motorcycle was a gem; garage kept, clean, only 2400 miles on it and started/ran great. I took it on a 30-minute drive home, no issues at all. Once it was shut off, I tried starting it back up again (hardly 2 minutes later) and it turned over but wouldn't ignite. It continued like this all night until it wouldn't turn over at all. Jumped the battery and it started right back up and let it run for about 30 minutes to burn fuel as it has been sitting, but died again shortly after.
Things I have checked:
Fuel - Put new premium fuel as well as stabilizer
Battery - The old battery was trashed; I bought a new battery.
Clutched safety sensor - Override to test
Kickstand safety sensor - Override to test
Circuits - Checked for any loose connections
Things that could be hints:
After purchasing the new battery, it immediately started right up with a loud roar. It ran perfectly fine for a quick loop. One thing that was noticeable was that the headlights and rear lights were flickering but would get brighter as it was being ridden/throttled. As we let it run idle for about 20 minutes it died on itself and wouldn't start back up again.
The owner said he hasn't ridden it for years on end, it was a pretty neglected bike.
Nothing changed - fluids, oil, etc.
I believe it to be something to do with the charging system, either that or maybe a bad fuse somewhere. Others have told to it just needs to be driven to break in the battery. This is also my first motorcycle, so would it be better to take it in for a diagnosis?
Any insight is appreciated!
