So, I've had a 1994 GSXR 1100 stuffed into the corner of my garage for several years. It is engineless (previous owner put it into a 750 frame), and it has a half-assed "streetfighter" headlight setup, but I don't care about those parts.
My question is about the fork. I've read for hours on GSXR swaps, but haven't found anything about these ones (yes, they're old).
From what I can tell, they're 41mm tubes, 52mm at the top clamp, fully adjustable KYB, with 6-piston Tokico brakes. I haven't measured total length yet, but they're pretty long (the 1100 clip-ons sit above the top triple clamp, not below). The steering heads are both close to the same height, too.
I've also read that they were not as good as the Showas from the same era, but they've got to be better than the stock damper rod and weak brakes, right?
Does anyone have any insight into this fork, and what it would take to swap over? Is it worth the effort?
FWIW, I've got an '03 naked, and I'm currently running a ZX14 shock and Sonic 0.95kg/mm springs with 15wt oil up front (I'm pushing 240lbs in full riding gear), 40mm sag front and 35 rear.
Thanks for any guidance y'all might have!
