Cafe Racer Build - Suzuki SV650 Forum: SV650, SV1000, Gladius Forums
Go Back   Suzuki SV650 Forum: SV650, SV1000, Gladius Forums > Workshop > The Build Board
Register Forums Garage FAQ Gallery Members List Calendar Search Today's Posts Mark Forums Read Motorcycle EscrowInsurance
The Build Board A place to post a journal or log of your SV / Gladius projects and builds. No replies or discussion are allowed.
Reply
Thread Tools Display Modes
Old 01-11-2012, 11:03 AM   #1
Harsh
Senior Member
Harsh's Avatar
Bikes: 2007 Triumph D675, 1974 Honda CB750 (Cafe Racer build in progress), 2002S-SOLD
Cafe Racer Build
I was given a 1974 Honda CB750 by my neighbor across the street. He was moving across counrty and didn't have the room for it. It had no title, looks like a pile of poo, and the electrics are shot, but I know I can transform it into a nice cafe racer. It took me a couple of months, but I finally acquired a title from Virginia. I obtained the title by going through the abandoned vehicle code of VA.
One of the first things I did was remove the tank and noticed it had a failed Kreem coating in it. Removed the coating with MEK, but noticed the previous owner broke off the petcock and then did an atrocious welding job to half ass fix it. Found a guy in Chapel Hill, NC that gave me a tank. Joe (silversx80) hooked me up and picked it up for me.
I then noticed that the front forks were bent. So the hunt began for some new legs. While at it I figured I might as well upgrade a little. I found a local guy that had a set of legs from a 1975 Honda GL1000. They are a basically direct bolt on. He also had the rear wheel that I picked up from him.
Last week I started tearing the bike down to facilitate pulling the engine. I checked the compression in the cylinders and all is good. Cylinders 1,3,&4 each had 110 psi. Cylinder 2 had 116 psi. I know those are a little low for what you would like to see, but I got them by utilizing the kick starter so I figure they were good enough. I have zero history on the bike. I know it has been sitting in a back yard for 4 or 5 years without anything being done to it. I don't even know if it shifts through the gears because the clutch cable is broken.
The day I brought her home
Failed Kreem coating
Horrible repair job
I picked up my new front end and rear wheel. I went with this because it has dual front brakes, aluminum wheels, and is basically a direct bolt on. I say basically because all I have to do is change out the bearings.
Last weekend I tried to remove the engine utilizing the "drop the bike on its side and slide the motor out that way" method, but it failed miserably.
I managed to wrangle the engine out of the frame. I wound up sliding a piece of steel rod I had in the garage through the rear lower engine mount. From there I was basically able to lift and slide the engine little by little until I cleared the frame. I was worried a bit that since I had the bike on my inferior T-Rex stand that everything would assplode.
Here she is on the bench
And after I removed the valve cover. Only two bolts required any real effort. I had to use some PB blaster and some heat to loosen the bond. Now I get to start the real work. I have never tore down an engine before so this should be interesting to say the least.
Took a while since I had to read the manual what seemed like a hundred times over to figure out what they were trying to say, but I got the head off.
Valve side...lots of carbon build up
And what the tops of the cylinders look like.
After I pulled the jugs off. It took a bit of banging with the rubber mallet to slowly work it up, but it came off without a hitch. I am a little worried to keep taking it apart since everything seems to look good. My intentions were to take it apart to see if I notice anything broken or wrong and to cleanup the block so I could paint it.
After some thought and consultations with friends I am going to do a full tear down and split the cases. Not know any history of the engine is basically what is dictating me at this point. For all I know it could have a spun bearing or broken primary chain or a whole host of other faults. This will be a somewhat long term project. Right now I am looking at probably $300 worth of replacement parts in the engine alone. The gasket set alone is a little over $100. Seeing how the Navy doesn't pay that well I will have save up before I can really move forward.
__________________
Check out my Cafe Racer build
http://www.svrider.com/forum/showthread.php?t=153263
Harsh is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-14-2012, 03:55 PM   #2
Harsh
Senior Member
Harsh's Avatar
Re: Cafe Racer Build
Split the cases today. Took a lot longer than it should have, but oh well. I had to make trip to the local Honda dealer for some tech advice. They have an older guy that works there that knows the CB's like the back of his hand. The manual just says to remove a particular bolt, but when I go to loosen it the crank shaft just spun. He gave me a trick to do, but I ended up not even removing the part since it was attached to the crank. The crank and attaching parts can come off as one unit after the case is split. The part I didn't remove is the thing sticking out of the engine to the lower right in the first pic.
And what the vast majority of a CB750 looks like in a tote
__________________
Old 01-16-2012, 04:42 PM   #3
Harsh
Senior Member
Harsh's Avatar
I got a fair amount accomplished today. Again I took it slow. My camera was giving me fits all day. I must have changed out the batteries three times. I guess my POS Canon point n shoot is giving up the ghost. Too bad the wife won't let me take use her nice camera. That is probably a good thing though.
Numbered for posterity sake. I put each bearing in its own labeled baggie. Top half of case.
Bottom half of case.
With everything removed from the case except one bearing which you can't see. I have to get a puller for that.
Bottom of the engine...It is nasty with A LOT of caked in goo in the nooks and crannies.
All clean (well mostly)
Inside of lower case after cleaning
Oil pan inside and out...NASTY
All Clean
Now to the bad...I broke two studs today. The PO put in these stupid studs so that they gut put on some bullet nuts on the outside of the engine. Well the studs are steel and the block is aluminum. I am going to go out on a limb and say they didn't use any antiseize or oil during installation. I was lucky enough to get all of the others out without too much of a problem. These two didn't want to budge so I have had them soaking in PB blaster. Well today I decided to try and get them out. I put on the vice grips and started to gently wiggle them back and forth. They appeared to be moving just a tiny bit with every back and forth motion so I kept going...slowly. Then the inevitable snap. I drilled out one of them and tried to use the easy out, but it wasn't budging. Not wanting to snap the easy out I tried some more PB and heat. Nope, nada, nothing. So they are sitting in some more PB. Luckily they aren't in a sealed area. There is one broken stud in each case half and they both go to the cover for the points. I guess if need be I can take them to a machine shop and see what they can do.
__________________
Old 01-21-2012, 03:49 PM   #4
Harsh
Senior Member
Harsh's Avatar
Got everything prepped for bead blasting tomorrow. I wanted to make sure that nothing got into oil passages or on bearing surfaces. I am hopeful that the entire case will fit into the blasting cabinet so I can blast it as a complete unit. If not, it is ready to be done in sections. I am also going to bring along the covers. The PO replaced the stock covers with some chrome pieces. The right side covers have a fair amount of rust on them and the chrome is pitting. The left side looks good and will probably polish up decent. The valve cover and a couple of other parts have a lot of oxidation and pitting on them and look pretty bad. Since I want all of these pieces to look the same I am contemplating blasting them to prep them for PC.
__________________
Old 01-22-2012, 07:31 PM   #5
Harsh
Senior Member
Harsh's Avatar
I got everything blasted today. It took a lot longer than I had planned. The cases went fast and easy. The jugs and head did not. Getting all of the old powder coat off of the fins was extremely time consuming. I ended up having to change the media to a more aggressive substance to get it to do anything.
I did a few of the chrome cover pieces, but all the blasting did was remove the rust and surface oxidation. They are pitted pretty bad and you can see some spots where the chrome is starting to lift. So I guess I have to find a way to remove the chrome and prep it for powder coating.
I also got the couple of broken studs out and re-tapped the holes.
A few before shots
And a few few after shots
__________________
Old 01-25-2012, 06:13 PM   #6
Harsh
Senior Member
Harsh's Avatar
Got the head and valves cleaned off tonight. It was caked on thick so it took a couple of coatings of Easy Off oven cleaner and some light scrubbing with a toothbrush. They are **** and span now.
__________________
Old 01-29-2012, 01:48 PM   #7
Harsh
Senior Member
Harsh's Avatar
Stripped all of the old gasket material off. Wow were the old gaskets ever stuck on there. I bought some Permatex gasket remover stuff to help break down the gaskets.
While waiting for the Permatex stuff to do its job I decided to do a little cleanup/polishing. I only spent about 20 minutes per part. They all have some scratches and some pitting, but should work. The chrome on the valve cover, breather cover, starter cover, and clutch cover are in really bad condition and are beyond polishing. There is a chroming place just down the road from the house. I am going to try and swing by there and see what they would charge to re-chrome or nickel plate the parts. I also want to see what they would charge to de-chrome some of the parts. I tried dipping a small part in some muriatic acid today. It looked like it started to remove the chrome, but was getting really smokey and hot. The parts where the chrome was already gone started to turn black. I got a little worried so I hosed the part off with copious amounts of water.
I also noticed that the rings on the #2 piston were seized and completely compressed. I have had it soaking in PB blaster for a day and have hit it with some heat a couple of times in an effort to get the PB to get between the rings and the piston to help loosen the bond.
I was able to remove the piston rings today. What a pain that was. Those things were **** near welded in there. They came out in tiny bits. The 3 piece oil ring came out very easily as it was never stuck.
I also found out that I will need a new countershaft bearing. The one I have has some grit in it I can't get out. You can feel it grind every now and then. So $10-$15 for a new bearing vice grenading the transmission is an easy decision to make.
__________________
Old 02-15-2012, 04:52 PM   #8
Harsh
Senior Member
Harsh's Avatar
Polished up my fork ears and the last couple of covers.
I also scored a few pieces on Craigslist today. Two sets of bars and the side covers I was missing.
__________________
Old 02-18-2012, 05:09 PM   #9
Harsh
Senior Member
Harsh's Avatar
Finally decided on my colors. It took a fair amount of time searching through the gazillion different colors, but I found the colors I am going to go with.
http://www.powderbuythepound.com/RAL...EELE_BLUE.html
http://www.powderbuythepound.com/AUT...LIC_PANEL.html
I was able to get the forks taken apart and cleaned up for powder coating. Unlike the SV's forks you must take out the screw in the bottom of the forks to separate the two tubes. They were absolutely nasty inside. The fluid had literally turned into a goo on the bottom.
I am going to PC the lower tubes in the gunmetal and have the blue put in the grooves at the top.
__________________
Old 02-23-2012, 07:08 PM   #10
Harsh
Senior Member
Harsh's Avatar
Seems like forever since I have updated anything. Well I unlaced the GL1000 wheels tonight and prepped the front hub for powder coating. I want to try and get as many things powder coated at the same time. I know frame and swingarm will be done later, but if I can get all the little bits done at once I think it will make it easier on me later on. I still have to take the rear wheel off the bike, unlace it, and prep the hub.
I noticed a little damage to the rear wheel presumably from a previous installation/removal of a tire. I don't think it will matter too much since the wheels and tires use tubes vice the tire sealing to the wheel. The damage is on the inside of the wheel so no one would notice it unless they went hunting for something. The front has a couple of knicks from previous tire installs, but nothing too bad.
__________________
Sponsored Links
Advertisement
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
©1999-2009 SVRIDER.com.
Ducati Forum Harley Davidson Honda 600RR Kawasaki Forum Yamaha R6
1199 Panigale Roadglide Forum Honda CBR1000 Vulcan Forum Yamaha R1
Ducati Monster Harley Forums Honda CBR250R ZX10R Forum Star Raider
Suzuki GSXR V-Rod Forums Honda Shadow Kawasaki Motorcycles Star Warrior
SV650 Forum BMW S1000RR Honda Fury Kawasaki Versys Drag Racing
Suzuki V-Strom BMW K1600 Triumph Forum Victory Forums Sportbikes
Volusia Forum BMW F800 Triumph 675 MV Agusta Forum Streetfighters
