1 - 4 of 4 Posts
Ok, I know that the 06-07 will fit without much work really and the 04-05 I will need to trim the battery box. I am just wondering if the length and/or the spring rate is different between the two? Thanks in advance for all your info ;D
'06-'07 - 8.3kg/mm - 464lb/in, 90-degree reservoir, left side
'04-'05 - 10.0kg/mm - 559lb/in, 45-degree reservoir, right side
I got this info from TheFleshRocket's thread on shock info from sv-portal.
1 - 4 of 4 Posts
