ZX-6R vs. ZX-14 rear shock comparison photos
11704 Views 54 Replies 14 Participants Last post by  abass84
2
Gold/red is from an '04 ZX-6R (636) - same style as '04-'05 ZX-10R. Black/silver is from an '06 ZX-14 (same style as '06-'07 ZX-10R). Note the different bottom spring perches, adjuster, and obviously the reservoirs. They seem to be the same length - around 1/2" longer than factory 2nd-gen SV. For reference, the gold/red ZX-6R shock DOES require cutting the battery box and adding a spacer underneath the battery. The black/silver ZX-14 shock does NOT (just have to remove a plastic shield on front of the battery box via three Phillips-head screws).
1 - 20 of 55 Posts
Reminds me to get that **** shock mounted
thanks for the info.
How heavy are you(if you don't mind telling lol) and how do you feel the shock has modified your suspension? does the height difference have an impact?
I'm a big guy at ~250lbs. At this weight, anything sprung correctly is going to make a huge difference over stock.
The raised rear is going to make the bike turn in faster making it seems more nimble.
An accurate eye-center to eye-center measurement on the ZX-14 shock would be useful.
Wow, that 636 shock is in great shape, usually they corrode like nobody's business. Get it framed!
Is it just a trick of perspective or is the ZX shock a good bit shorter?
hey do you know the length on the zx14 shock exactly? if its the same or near the 636 then its 338 mm right?
thanks
justin
thanks
justin
It's 330mm - same as the 2nd gen stock shock.
:iamwithstupid:
It did seem a little lower than the ZX-6R shock, but I installed a GreatDaytoRide.com-lowered seat at the same time as the ZX-14 shock, so I wasn't sure.
I'm sorry, I don't have an accurate measurement. It does seem as if the ZX-14 shock is a little shorter than the ZX-6R shock, but I installed a GreatDaytoRide.com-lowered seat at the same time as the ZX-14 shock, so I could be wrong. It does seem a little lower...
maybe around 8mm? ;D
YEAR MOTORCYCLE LENGTH SPRING
00-03 GSXR750 325mm 400#
01-03 GSXR600 325.5mm 325#
01-02 GSXR1000 329.5mm 430#
03-04 SV650 330mm 430# <<<==== stock 2nd gen...05 should be the same
99-03 GSXR1300(Busa) 330mm 700#
04 GSXR750 332.5mm 408#
04 GSXR600 332.5mm 425#
03-04 GSXR1000 332.5mm 480#
99-02 SV650 337mm 510# <<<====stock 1st gen
04 ZX10R 338mm 540#
03-04 ZX6R(636) 340mm 540# *corrected by e lo...thanks!
96-99 GSXR750 345mm 375#
97-00 GSXR600 375mm 375#
05 GSX-R 1000 332.5mm 450# <<<===added by me...spring rate from racetech.com, length from ohlins.com
<end>
tis is what i found on another site as ans as far as i can tell the sec gen is 330 the 1st is 338 and zx are right around 338
My recently installed '07 ZX-14 shock raised the seat a tiny bit compared to the original SV shock. Not much, but definitely higher, not lower. I'm nearly 6' tall so I have no problem with the extra lift.
As yet, I've not taken the time to properly adjust the new shock: I figured I would ride on it for a couple of weeks and get used to it, then I'd be better able to fine tune the adjustment (I'm also trying to lose a few pounds at the moment). Rebound and compression are both set at 2 turns out from full stiff, and preload is set pretty light.
Adding more preload might raise rear of the bike even more but I have long legs. This is how the shock went on my bike:
My guess is that the bike only seems taller because it doesn't squat down as much with you on it. I experienced the same thing.
Yes, that's probably true. The squishy feeling when I climb onboard is gone now. The ZX shock definitely supports my fat arse better than the OEM shock.
I know exactly what you are talking about.
The first time I sat on the bike to set my sag I was like woah, the bike hardly moved!
Can the same tool for our stock shock adjust the preload on this shock? What is a fair price for a used zx14 shock? 100, 75, 50?
Yeah I used the tool that came with my bike.
I'd say somewhere between 50-100 is a fair price.
you can also just use a flat head screwdriver to to turn those preload adjusters.
1 - 20 of 55 Posts
