I just bought my 99 SV 2 months ago with 19.5 k on the clock, it now has 20,500 on it and I figured I would check the valves. Rear cylinder intakes were both at 4 thou, and left ex was at 8 thou, while right ex was at 7 thou. So i assumed that the front cylinder would be fine as well, glad I decided to check it.
Front cyl - left ex was 7 thou, right ex was 8 thou. Then I TRIED to check the intakes, the smallest feeler gauge I had was a 2 thou, and it would not slide under either intake cam lobe. I could not even get it 1/8 inch under the lobe, and the 2 thou is almost as flimsy as paper, so it got bent all out of shape with me trying to stuff it under there.
At first I figured I did something wrong, so I went and did all the steps over again, and got the same ex measurements, and still nothing on the intakes.. there is no possible way to screw up that bad is there?
Tomorrow, I am going to try and put aluminum foil in there for measure, doubled over, the foil measures 1 thou. Has anyone else heard of this kind of thing happening? I have yet to tear the cam out, but when I do, I will post up the shim size and see whats what.
I have no previous history on this bike at all, it runs up to 125mph, idles fine, gets 40-48 mpg, it runs great, except that it is a PITA to start when it is cold, it only runs on one cylinder for a little bit. I hear that is sometimes a symptom of valves being out of spec, either that or its just my stock jetting.
