21 - 27 of 27 Posts
So the speedo is back on the bike, everything is connected but it is still not working?
I imagine the repair tech would have tested the unit before sending it back to you, no?
How are you testing the Speedo?
Is the bike back on the road and running fine? When going for a test ride do both the odometer AND speedometer fail or just the speedometer?
Check to see if the speed sensor is sending pulses to the gauge. Back-probe the Pink wire at the speed sensor connector (inside the headlight shell).
WIth the key On, raise and spin the front wheel. If the speed sensor is working you should see the voltage toggle between 0v to 5v.
If the sensor signal does not toggle then likely the sensor rotor is bad (easy and cheap to replace) or the sensor itself might be bad. If the sensor signal is good then the problem is at the gauge, gauge connector, or interconnect wire. Good luck.
54704
Thank you - will do. Incidentally, I get 4.5v at the pink FROM the speedo, where does the power into the speedo come form?
21 - 27 of 27 Posts
