As the title says, I have done extensive amounts of research and have yet to reach a satisfying conclusion so I figured I would bite the bullet and ask, hoping it has not already been answered in some stickied post that I missed.
I currently have an 05 SV650S that I picked up as a barn find for next to nothing, it came with quite a few issues but the frame and engine were intact and in good working order so I decided to make it my project bike of the month. As of right now, the bike is almost done with its rebuild with only cosmetic improvements to make last. The one major issue that I am stuck on is the rear shock. I went the route of doing a GSXR front end, using a complete front end taken off a 07 SV650 that was a race/track bike (the front end is originally from an 07 GSXR 600). I thought this would work well as it was already set up for the SV and was sprung for my weight (190lbs). After install, I noticed that the bike handled very suspect at low speeds, and felt like it wanted to twitch and dive whenever making low speed maneuvers, quite unlike the track bike, and I am assuming it is because of the rear shock setup. On the track bike it has an Elka double clicker that is set up for 180lbs rider, whilst on my 05 SV it still has the stock shock (probably never even been touched for maintenance by the look of the bike) that is set up for whatever weight it comes stock.
After my research, I see that a lot of people go the route of an 06/07 ZX10R surrogate shock, but I would like to know if this could or would help my current problem and pair nicely with my GSXR front end, or if I need to go a different route. I also have seen that some people put fork extenders on their GSXR swaps to raise the front ride height for stability, but from what I can tell running a 120/70 tire on my GSXR front end is 12mm higher than the stock SV tire and balances out the loss of height from the forks.
Any help is greatly appreciated!
Cheers
Cheers
