Thanks for good replys guys and Nate, I'll take it to tha Summit Point track on august 16th so I'll be able to dial front and rear. Alighnment was the most difficult work but at the end all I used were 3 high grade metal washers I need to look at what size are those, also spacer could be used. Ran through all the gears and it spins smoothly. At the begining I thought it was going to be the most difficult part to match the swingarm axle, but it turned out that OEM SV spacers from both sides slid into the gixxer's spacers like they were ment to be there so I could use original SV axle. There is some grinding work involved in the shock area, it fits with no problems there but as soon as tried to move swingarm up to mimic compression it hit aganst the spring. Linkage is shown on pic the bolt(Gixxer since it's longer) on the left side stiks out about half an inch I used SV shock mount spacer there, then I had to cut thru the gixxer swingarm linkage where the second dog bone was originaly on SV so it slid in and bolt went through then I used gixxer spacer that I had to cut to match with the end of swingarm linkage's end. So even the bolt sticks out a little it still there securely since both spacers are holding it in place. Kinda confusing but once you'll start doing this mod you'll know what I'm talkin about. I dont know how the whole bike will behave after this mod, basicaly nothing had changed exept bigger wheel :lol: and braced swingarm, wheelbase remains the same. Hope it helped for someone whos planning on doing that. Next thing to do is weld aluminum around the swingarm if it runs perfect then I might get lighter aftermarket wheels and better tires.
