I went to go install a Woodcraft Keyless ignition on my 2001 SV650. It has gen1 gauges mounted to a GSXR main fairing stay. I verified the electronics work without the gauges connected; however, I have no idea how I can get the front gauges connected without making up a ~24" 6pin extension from the green connector near the airbox to the Woodcraft keyless ignition piece.
The issue is that in order for the gauges to be connected, you need to run the main harness (left side of frame) out to the gauges/headlight sub-harness, and then to the right-side hand controls. If it weren't for the need for the gauges, I think I could actually just tuck everything under the tank.
Before I go doing some research on how to put together a 2ft extension from the green connector to the Woodcraft piece, I figured I would ask if anybody has done this before. And am I missing something really obvious and basic because my search results are turning up absolutely nothing related. The Woodcraft instructions are universal and not bike-specific.
Green connector disconnected (no burn damage, good).
Headlight/gauges subharness connected.
And you can see just how far I have to go. Further than this looks, actually, because I need to tidy/mount harness to the mount.
And then short 30s video in case my explanation wasn't clear.
It seems like I could make an extension from the green connector to the pin black woodcraft connector if I can figure out what the correct connectors are. I'm just curious if that's actually necessary though. Any insight is appreciated.
