Ok my bike won't start after my crash. It appears it was mostly cosmetic damage but my clip on, clutch side is completely destroyed and my clutch side rearset is destroyed. There is no linkage between the motor and rearset right now. The bike is in neutral. The electronics seem to be fine on both clipons. The bike will turn on electronic wise but will not turn over at all. The clutch lever is broken and it's extremely difficult to pull the clutch cable back. I'll try to post pics later. I need suggestions asap as I'm trying to determine if the bike will be worth to buy back from insurance or not. I was thinking maybe the tip over sensor? All help appreciated
If your clutch lever and perch is all messed up, the switch there that needs to be engaged when starting the bike is probably your problem. Or possibly the tip over switch located on the battery tray may have come loose and thinks your bike is still on its side.
I'll give both those ideas a shot. Thanks guys. I'll keep ya updated
the paperclip jumper between the contacts worked like a charm. Thanks. Now to solve the smoking out the tailpipe issue...........lol
