I tried sliding this in and the holes did not match up on the one side at all. The top screws could go in and the bottom screw on one side only would work. The other ones were slightly off and were not able to be used.
Even lockhart says it is for 03-05 whereas their other screens say till 08...
I have no issues gettin any screens in on my other bikes nor getting either of the two OEM ones I have in...They all slide in easily.
I am thinking that too. I might just dremel out the new windscreen holes to be slightly larger. I did get it for $28 so it is not like it is a big deal.
soulpatch, it's hard for me to explain, but i guess put them azz to azz? with the bubbles on each facing outwards. if the holes line up, the new should be fine----might need a little more force to put in. mine was a pain to put in too when i took the front cowling apart.
Some screens take a little persuasion. That is the correct screen, just sounds like hole placement was less than perfect during manufacturing. I have had to use a small screw driver to line up before on some bikes/screens.
Last night I was at work late so it was dark by the time I made it home to look at this all. I will get to it tonight.
I figure no matter what I will just dremel it to make it work. I bought the screen for all of $28 or so, so I figure I could almost destroy it without any worries.
76K members
