1 - 11 of 11 Posts
In the same sense as the gsxr shocks fit (you need to hack the battery box and may need to change dogbone length) It might actually still be too soft.
i need to change the rear shock for racing. normally i would just throw a penske on (like my last one) and be done with it. but penske has upped their prices and the new $800 price tag is a little high so im looking for a good less expensive alternative. even if it was 1/2 as much i would be happy.
SV Hadder
If you absolutely must swap in a shock from another bike, go with a gsx-r or ninja one (depends on your weight and the generation of your bike. check the FAQ)
Did you look for any used stuff on the WERA bbs?
If it's for racing I can't see why you wouldn't pony up the extra jack for a performance shock.
at least its adjustable though
If the length, spring rate, and damping are wrong exactly what benefit does it being "adjustable" provide??
Even for moderate street use there aren't any good OEM shock swap options for the first gen SVs, for racing use it's absolutely not worth considering.
Discussion Starter · #10 ·
i was just curious. they both have *similar* geometrys so i thought that the 1k would be a little stiffer but adjustable. but if its gonna be the same as a GSXR swap then ill have to start saving
WERA is the only place i havent looked. trust me i want a penske, but the last time i bought one for an SV it was $600 at the most...now its $800. that really cuts into my budget for the front end and tires and bodywork, blah, blah, blah....
1 - 11 of 11 Posts
