common knowledge is that synthetic oils are too slippery and do not provide enuf friction between surfaces when machines parts are mating. With modern machineing technology (if used in the manufactureing process by a particular manufacturer like Porche) it is likely that the machineing is so good that breakin is not necessary or requires less friction.03Dynasty said:Why is it so important to break a bike in for thousands of miles before using a synthetic oil? Thanks
Good point!! I know that a lot of Porsche owners dont change their oil except for every 10k miles or sometimes more...just because it isnt necessary on these cars...RandyO said:common knowledge is that synthetic oils are too slippery and do not provide enuf friction between surfaces when machines parts are mating. With modern machineing technology (if used in the manufactureing process by a particular manufacturer like Porche) it is likely that the machineing is so good that breakin is not necessary or requires less friction.
