Why is static sag so important?
AFAIK static sag consist of a certain amount of travel or stroke calculated with the difference between the motorbike suspension being fully extended and then dropped with its own weight.
I saw a lot of videos from Dave Moss and he always pull up the rear of the bike to determine if there's a correct amount of static sag or it's almost non existent.
The problem is that for heavy guys with the proper spring the motorbike weight will always be pulled up, and the stiffer the spring is, the less the bike will come down, reducing the amount of static sag.
But all this is is totally independent from rider sag, because in order to reach proper rider sag numbers with the proper spring and preload, you will ways sacrifice static sag. If somebody tells me I have almost no static sag and tries to take out some of my preload, it will obviously increase my rider sag.
So I would like that somebody explains me this kind of dilemma, and where is the trick.
