that is not what I said, I was not talking about through a turn, I was talking about controlling your speed going down hill. I reread my post and cannot see where you got your criticism from...maybe you should read for comprehension.Are you talking about being off the throttle through the turn? If so, that's very bad advice. Coasting or or engine-braking mid turn will destabilize your suspension and give you less control when you need it the most. You must learn how to properly set your speed and use your throttle through the turn.
