My buddy has a er6n with those bars on it. Measured for fitment and found mounting bolt measurements different. Thenks for the responce.
It looks like they bolt into the lower half of the bar riser's. Are the riser's cast in or bolted in to the upper triple on the gladius?
If bolted in, it'd be pretty simple to make adapters.
Figure out the size block you need and call around to some local machine shops and see if they have scrap/stock aluminum they would cut to size and sell to you. Then all you need is a ruler, punch, drill (bench preferred, but you could do it with a hand drill if you're careful) and tap.
