I'd recommend sport touring tires for your riding, especially if you put miles on quickly. They tend to be long lasting and good in cold temperatures and rain. You can't go wrong with Michelin or Metzeler. I would go with the Metzeler Roadtec 01. The Metzeler Z8 is an older design, but is a good tire and should be cheaper than the Roadtec. The Michelin Roads are good but quite a bit pricier.
A lot of people go with a larger 120/70-17 tire on the front. It partially corrects the speedometer error, handling is a bit less twitchy, and tire availability is better. The larger sidewall could help prevent another bend in your front wheel as well, which are pretty common with these bikes. Definitely stick with the stock size on the rear.
