1 - 20 of 21 Posts
Do ya'll know of any good places to get upgraded aftermarket internal engine parts. Like cams or pistons. I am interested in doing some internal work this winter but I don't know of any good places to look for them. I haven't been to the local bike shop that I go to here yet either.
We can source all of the usual stuff, and we're also a U.S. distributor for JHS Racing engine packages and components, just don't have it listed on the web site yet. I have a JHS superbike motor in my bike and it's been great!
Does anyone know how much hp the stock block can handle. Like say if i got it borded and replaced the pistons and cams.
for how long? :)
anything over 85 is to much for daily use.
The crank is the weak link, not the cases. :D
At ~85 hp the cases will be fine and last a long time. Go above that and the problems start for street engines. Bore the things out and raise compression and you'll have a gerenade waiting for some weak 86/87 octane to detonate on!
Thats what I want to do. And replace the pistons and cams, but how much hp do you think that'll make. Also is i changed out the crank and was over 85 hp what kind of problems would I have?
TWF said:
for how long? :)
I'm not really interested in making it for daily use. I wanna do something unique and different that a lot of poeple dont do w/ the sv. I defintally wanna go over 85 hp.
Here's what my JHS motor did during the last break-in dyno run with stock CV carbs. With my 41mm flatslides, it's probably low 90's HP now, will know for sure next week when I get it dyno'd again. You need minimum 105 octane race gas for this type of motor. It's 2mm overbore with 13:1 compression, very light crank and flywheel, hot cams, lots of other internal tweaks. I wouldn't want this in a street bike, but it pulls like a mofo on the track! 8)
Sweet let me know how it turnw out.
Not to pull the BS flag or anything here, but aren't you from Nebraska? Did you send your bike all the way to JHS in Brisrol, UK just to throw it on the dyno and break it in? I should do that too, after 62 runs I must be over 95 HP! :p
Well it could be that the motor is JHS built, dyno'd there in the UK, then shipped over...
Questions for you SVRaceShop guys:
1) Does Falicon make a stroker crank that works in 2nd gen bikes? All I see are 99-02 1st gen so I'm assuming (ASS-UMING) that the cranks are diff.
2) Are there any big bore piston kits (3mm+ overbore) that will run on 92 octane w/o detontation/pre-ignition probs?
An SV808 would be interesting. :)
James built the motor for me at JHS, mounted to a chassis for dyno break-in, then removed and crated, and shipped to our shop.  It's really pretty reasonable to ship crated motors, we do it all the time.
Yes, there a Falicon stroker for the 2nd Gen SV. You can go big bore and still run on pump gas, it's a function of compression not bore, so as long as you keep the compression down it's fine. We just fitted a bike a couple weeks ago with a 700cc kit that runs on pump gas.
Discussion Starter · #17 ·
How could I get some info on that?
1 - 20 of 21 Posts
