1 - 12 of 12 Posts
will a GSXR front and rear wheel fit onto an 04 SV 1000? or do I need other parts to make fit? what is the rears width?
Les
doesnt the sv1000 allready have a 5.5 inch wheel with a 180 tire.
which is same as the gsxr wheel...
i dont know anything about the 1000 tho...
then why are you answering the question huh? huh!? ;D
As of right now, I have the wheels from my 2001 GSXR 600 on my 2003 SV1Ks...the wheels and tires are exactly the same size. Just use the spacers and cush drive from the bike you are putting the wheels on, and all should fit fine.
and front rotors.
TWF said:
and front rotors.
Nope, had to take the rotors from the SV wheels and put them on the GSXR wheels....blue loctite, what a PIA. ;D
that is what I ment,rotors are not same.sv is 310 and gsxr 320.
Yep, found that out as soon as I went to mount the calipers back on..damn Zuki. ;D
they keep changing rotor size lately.I think 05 gsxr1000 is 305 and has different bolt patern.in 06 looks like they going to 310 on gsxr's.
I didn't care about having the change the rotors over, it was the two allen keys I bent to hell and one allen socket I broke trying to get out the bolts, that go in with 16.5 ft/lbs of torque and blue loctite, but take a miracle of God to get out with out stripping the heads ;D
best part is you dont know it will strip bolt untill it does :)
use some valve lapping compound and put some on bolt and/or allen.it grips better.
1 - 12 of 12 Posts
