Im installing a vapor computer, but was wondering what everyone does with the speed senor off the old gauges. Does it serve any purpose as a wheel spacer or can it be completely removed?
I can't speak for the Vapor, but I can for the Acewell computer I installed. The stock speed sensor has 3 wires, where the Acewell computer has 2 wires.Why not just use it to drive the Vapor instead of adding the Vapor one?
just recalibrate in the set-up on the wheel size for the multiple pulse counts.
You already have the wiring right there to the connector plug anyway .........
The three wires are power, ground & the output signal - not too complicated.... The stock speed sensor has 3 wires, where the Acewell computer has 2 wires.
