1 - 20 of 27 Posts
Or is there any difference whatsoever? Pretty limited in time and tools. I'd like to install a highmount slip-on can for a 1st generation. Want the easiest/cost effective solution that I can still be proud of. Also, I've read many different opinions as to whether or not you need a retune or whatnot afterwards. Keep in mind that I have the carbureted model. Thanks for the help. Peter
I installed a Scorpion highmount and love it! Id reccomend a Sawzall for removal of the stocker, of course youd need that on anyone though. Check out www.buycyclegear.com thats where i got mine. Good price and friendly customer service. But this is just my own humble opinion.
+1
Sounds great guys. Thanks for the info. Do I need any special attachments? Do I need to remove the rear pegs or anything like that? I've read that some high mounts need other alterations. Really lookin' for the easiest cuz I'm lazy. ;D
Oh, that looks awesome! Do I need too change out the rear turn signals?
the scoripion comes with spacers for the rear pass peg, and you'd probably need smaller signals for the rear as well
OK. What do you recommend for the signals if I go for the Scorpion. Thanks a bunch! :) Signals should be easy right?
i did the hotbodies undertail. pretty simple but you'll need a plate light if you wanna make it legal
So you're not at the meet spot either. LOL
Discussion Starter · #14 ·
Can you give me a link? Thanks.
Discussion Starter · #17 ·
Wait. How is this a replacement for the turn signals? Isn't that just a brake light? I'm confused.
Discussion Starter · #18 ·
What did you do to defeat this problem? Thanks.
it replaces the entire rear fender. look closer, the little LED things under the brake lights are the turn signals
i didn't ;D
i'll put up pics tomorrow of what it looks like if you can wait. or someone else can. i'll chekc back tomorrow(gotta run now) to see if some has responded. if not i'll throw some up
1 - 20 of 27 Posts
