if i pick up this http://cgi.ebay.com/ebaymotors/Part....c0.m245&_trkparms=72:543|65:12|39:1|240:1318 What else would i need to complete the swap?
No. The actual swap is quite easy if you have all the parts at hand.Do you think i will have problems?
I don´t know. You can see from the outside that the axle design (or at least the way it is fastened) changed, but I don´t know of the consequences or whteher there are other changes as well. The rotor bolt pattern and rotor diameters are different, too. The latter is not really a problem with the radial brake mount - wheel width would be a bit tougher.do you know by chance if a 07 600 wheel would work with the 04 05 front end.
Yes, that wheel should work.do you know by chance if a 07 600 wheel would work with the 04 05 front end.
You cannot run a newer gsxr rear wheel without machining it first. I believe you have to take some material off of both sides.mine is a 03 naked. im actualy redoing the whole bike. i have lower fairings, and am going to be powdercoating the frame and swing arm and all silver parts black. Im going to be using a acrbus cyclops headlight. Im not sure what im going to be doing about a speedo yet but i hate the look of the big thing on it now.
Im also not sure whta im going to do with the rear shock or the rear wheel yet. Would i be able to run a rear 04 05 gsxr 600 wheel?
Not unless you get custom spacers for the calipers. 04/05 has 300m rotors and the later model has 310mm rotors.do you know by chance if a 07 600 wheel would work with the 04 05 front end.
Right, you will need spacers to use that wheel. You should be able to get 5mm spacers from yoyodyne or our own DougZ.Not unless you get custom spacers for the calipers. 04/05 has 300m rotors and the later model has 310mm rotors.
The 300mm rotors will not fit on the later wheel.
So either get an early wheel or have some spacers machined
Are you planning on upright bars (per current naked) or clip-ons?
Yes. They are all 22 mm in diameter.Will all my levers and throtol and what not fit right onto the gsxr bare clipons?
