Did you do your clutch adjustment up at the lever or down by the engine?Adjusted my clutch. realized that my disappearing oil problem could be from the sprocket shaft seal. I forgot what its actually called. Have to clean it off real good and run it. Also giing to run a compresion test to check the rings.
Sent from Motorcycle.com App
I wanna do the same thing but need to learn a little more on how to first
A compression test will only tell you whether or not you're losing compression, it won't tell you where you're losing it. You want to do a leakdown test for that. That'll tell you if it's the rings, intake or exhaust valves, head gasket, etc.Also giing to run a compresion test to check the rings.
This can workI also figured id do a dry compression test and then a wet one to tell me if im possibly losing oil from the rings letting it by.
