Worthless
Rockrat, sorry I never knew you cared.
This is for an SV1000 not a 650.
The bigger motor is not as smooth as the 650. It also had an annoying vibration around 6000 revs. I surmised it was the spark retard in the first three gears and a corresponding leaner mixture. Was right on both counts. 5 degree retard.
Not everyone can reprogramme the ECU, but Nels can.
So with the timing advanced and the fuel supply adjusted, the vibration has mostly gone.
By the numbers from memory. The tach lies, shows about 11,000 revs when actually at 10,200 WOT. 152 mph, 108 hp and around 65 pounds of torque, flat across most of the rev range. Later we will try for 120 rear wheel hp and 75 torque. Whether the actual top speed matches the dyno, depends on wind resistance needing 108hp to do 152, or whether Bluzu may go a bit faster.
There are extra revs available, or maybe one more teeth on the rear sprocket.
But 150 plus is plenty fast enough. I have been close and Bluzu had lots of steam left.
There were several SV650s at The Ridge race track in WA, but zero SV650 non racers. One bike has been enlarged to 700 plus cc. runs well.
Unkle Crusty
