Lockhart Phillips LED...inexpensive and actually they were cheaper locally than buying them online. I would have preferred plain back, but for some reason the carbon fiber look was cheaper. I don't really care, I just needed working blinkers.I noticed the same thing. I think it's because on hazard, you have both stockers running, so there is enough current draw to slow down the rate.
What signals you get? Pics or thread?
I would be interested in seeing how those signals work. One of the main reasons I haven't switched to LEDs is that I don't like a clear lens on a turn signal. For some unknown reason, I think motorcycle signal lenses must be amber. Since those are in the exact same housing as the incandescent ones I have, I could get the LEDs and put the proper amber lenses on them.Got the front turn signals installed and when I get back from my appointment for w**k, I'm going to tighten everything down after adjusting the headlight down.
I'd like to know how bright they are.Lockhart Phillips LED...inexpensive and actually they were cheaper locally than buying them online. I would have preferred plain back, but for some reason the carbon fiber look was cheaper. I don't really care, I just needed working blinkers.
I don't think I've posted a picture of the bike since I got it, but I bought it from J-Dog and he has pictures floating around here of it. I should post some even though nothing has changed cosmetically until I changed the signals yesterday and I take the NESBA sticker off the front fender.
The LEDs blink a bright yellow/orange. I like them so far. I'm going to spend the $12 or so on the relay and get the blink rate to slow down.I would be interested in seeing how those signals work. One of the main reasons I haven't switched to LEDs is that I don't like a clear lens on a turn signal. For some unknown reason, I think motorcycle signal lenses must be amber. Since those are in the exact same housing as the incandescent ones I have, I could get the LEDs and put the proper amber lenses on them.
I think they're brighter than the incandescent white bulbs behind amber lenses I previously had.I'd like to know how bright they are.
I guess the laws are different from state to state. What about an integrated brake light that's red for running light and brake light but blinks yellow for a turn signal?
Thanks for that tip. I'll definitely look into it. The signals that were on there were cheap ones from newenough and they worked alright until I lost the left rear. I have some silicon seal for a window that should work just fine.Something you might want to think about is putting some silicone between the rubber and bulb housing. I've tried a couple cheaper leds and always had moisture get into the leds and burn them out. Plus the inside rusted and turned brown and made them look like poop.
They'll be fine. They're just short stalk markers. No more narrow than what was on there previously and they passed inspection about 3 months ago.These work... but you may not be able to get away with it in your state... some have laws that signals must be x# of inches apart... so the integrated ones are deemed illegal... but you could probably toss a couple extra small leds off the side somewhere as backup...
You bought a cooper or aluminum washer, right?went to the hardware store to buy a new washer, put everything back together and added new fluid...... hopefully the lost washer won't cause me any trouble!
I got home and installed a Michelin Pilot Road 2 rear tire. Put some light scratches on the rear wheelI inspected my back tire. It has cords showing. Must be time for a new one.
It's a Bridgestone BT-016. It lasted 2750 miles. Not very good, at all, considering I put it on in the fall and have mostly ridden slowly because of rain and cold temperatures.
