Galfer Black Pads (GG rated)
GG rated pads out-perform most original equipment pads (which are usually G-rated only) by maintaining functionality at temperatures as high as 700 degrees. They offer extreme versatility with the ability to be used on both front and rea. These Semi-Metallic & Carbon pads offer great longevity while limiting rotor wear. These pads will give you a strong progressive feel allowing for a controlled braking modulation.
Composition: Semi-metal, Carbon Installation: Clean rotor surface & bed-in with easy braking first 60-120 miles.
Galfer Green Pads (GG rated)
The Kevlar-organic Green pads offer powerful, initial bite time after time with no fade. The versatility of these pads is unmatched. They can adjust to abrupt temperature and moisture changes and take little time to recover between braking. They can be used in all types of riding whether it is street, dirt, race, and any combination of each. These are better for an aggressive rider, since these offer one or two finger stopping power. For many riders, the ideal combination is using Galfer Green in the front with Galfer Black in the rear. If rotor wear is of great concern, the Galfer green would be an optimum choice. They won't last quite as long as the black, OEM or the HH pads, but their soft, organic material composition causes minimal damage to the rotor surface.
Composition: Kevlar, Ceramics, Basalt Fibers Installation: Clean rotor surface (be extra diligent in cleaning if following an HH (Sintered) compound) & bed-in with easy braking first 60-120 miles.
Galfer HH Pads (HH rated)
This sintered metal & ceramic composition allows for the ultimate friction, making their stopping power unmatched. It will provide instant powerful braking intensity in any weather condition or speed. The ceramic coating on these pads disperses the heat evenly, keeping the brake fluid temperature lower. This minimizes brake fade. These pads also have a longer life span than most other pads because of the high metallic content. These HH pads are rougher on rotor surfaces but work with optimum performance on Galfer Brake Rotors and other high-carbon content discs. Despite this assumption, these pads have remained popular with the aggressive off-road and street riders and are supplied to many race teams.
Composition: Sintered Metal, Advanced Ceramics, Carbon Fibers Installation: Clean rotor surface & bed-in with easy braking first 60-120 miles.
