1 - 12 of 12 Posts
Drained my oil and found not only metal shavings but a chunk of something that is either metal or a porcelain looking material. It's about a 1/4 size of an almond slice, it is glazed brown on one side with a curve to it and the other side is a metal shaved looking area that has layers to it.
When i bought the bike i was told it had 19,xxx miles. I've put 5 race weekends on it. The last T-Hill event the bike ran super with no out of the ordinary noises, clunks, bangs, or anything else. This is a bone stock engine.
Any ideas of what it could be? Zoran, what's your thoughts?
Sounds like a chunk of friction plate from the clutch, but I may be misinterpreting your description.
Got pics?
sounds like it is piece of epoxy from magnets.it is common to find epoxy breaking off on spots.
dont worry about it.
now do you have a CLEAR picture?
That there is an SV egg. If you sit on it for 9 months it'll hatch into an SV400. Then if you feed it and nurture it it'll soon become a 650 or even a thou. You lucky feller.
Good Lord man, are you saying when you dumped the oil out of your drain pan there was a rear sprocket in there? :eek:
1 - 12 of 12 Posts
