"Service Manual Quote
1. Lift Fuel tank...
2. Ingition switch on
3. Disconnect the water temperature switch lead coupler.
4. Check if water temperature indicator lights up when
grounding the the lead wire coming from the main
wiring harness with a jumper wire."
Can you please tell me what 4. means?
I just want to check to see if the Water Temp indicator light works.
Thanks
Thanks
