1 - 13 of 13 Posts
Hey guys I have coolant leaking in to oil after a clutch replacement so I’m doing a water pump rebuild problem is I can’t get the impeller shaft out any help would be amazing
I have always removed circlips of the lower type (actually eclips) with a small flat screwdriver inserted in one of the recesses, and reinstalled them simply by pushing.
53740
Circlips (the upper ones) I have always used the proper Seeger tool.
Discussion Starter #9
Yea I brought it my mechanic friend it’s an e clip/c clip which is why the circlip pliers weren’t working lol
This will require a punch and soft hammer or an internal bearing impact remover.
The seal is the hardest part. That came out in two parts eventually.
Sent from my SM-G965F using Tapatalk
Since you have started multiple threads for the same issue, I'm wondering if you have read the relevant sections in the service manual. All the procedures are described there quite detailed. Get it here:
Section 6.14 explains everything in detail.
I'm wondering why you think you need to disassemble the impeller shaft bearings. Did coolant come out through the hose attached below the water pump? If not, the impeller seals are fine.
Run water over the shaft and spin it. Nothing should come out of the drain hose.
Replace the one large and two small o-rings and carefully follow the steps in the service manual.
Wasn't your problem due to the gasket not fitted correctly because you didn't use the dowel pins?
Discussion Starter #13
Thank you this was very helpful
1 - 13 of 13 Posts
