1 - 20 of 30 Posts
I was just wondering what products everyone uses to wash their bike. How long does it take? And is there anything I should be careful with while washing?
Liquid laundry detergent and fabric softener, plus engine cleaner for the really nasty bits. The fabric softener minimizes spotting.
I've had OK (just OK) results with S100, but I had a really bad experience with the similar Motul product* so I don't use any of those any more.
*Even used exactly as per directions, it stained the painted plastic parts on my ol' Bandit horribly -the painted parts were fine, but I had to compound the plastic to get it looking halfway normal again.
I've had good results with S100, but I've found a cheaper alternative-- painted wheel cleaner - normally used for painted/clear coated alloy wheels on cars and trucks. I dilute the wheel cleaner with water 50/50 and put the mix in a spray bottle. It's pretty much a spray on/hose off operation. It's still a good idea to test whatever cleaners you decide to use sparingly at first.
So it is possible to have clean and shiny bike without spraying the thing down?
You can get a pile of rags and go to work on each part of the bike with a light cleaner... but it's time consuming.
I use eagle one's spray and wipe detailer. It's similar to Meguiars spray detailer. Works wonders.
I use a good ol hose, a bucket of hot water with car wash solution in it, and a micro fiber towel. Rinse, blow dry with the leaf blower, then either hit it with Meguires quick detail or go through the wax routine.
Takes a bit of time, but I enjoy it. Good quility time in the garage/driveway with the bike and the dogs. :D
Discussion Starter · #10 ·
It says in the manual not to run water over certain parts of the bike...sparkplugs etc. I'm just paranoid because I don't think I know how to run water over the bike without it contacting these parts. I'm pretty new to this.
Lemon Pledge
You have to figure that if you're out riding and get caught in a downpour, most parts of the bike are going to get wet anyway. I think Suzuki means they dont want you pressure washing certain parts. That would definately force water into places it shouldn't be.
I never substitute water pressure for elbow grease, I usually use a garden hose with just enough pressure to rinse away the soapy cleaner and dirt. Also, I usually avoid spraying the handlebar/speedo area directly. I clean this area with a damp rag.
I wash my bike and all the bikes prior with a hose and bucket of carwash soap.
No problems. Blow dry with compressed air.
gonzo221 said:
i use mr clean auto dry. Works great and no need to dry it. comes out sparkling everytime.
http://www.homemadesimple.com/mrcleanautodry/index.shtml
+1
And cheap microfiber towels from walmart.
Meguiar's three step wax.
I use a kitchen degreaser spray on the wheels, soap and water just doesnt seem to cut it there. It's a little time consuming, but I usually do it last, while waiting on my current coat of wax to dry.
just use some car wash, with wax in it. although, if it didnt have wax on it before the season, i would get a clay bar and get all of the bug gunk off of it first... then go over it with the car wash and wax together. That way, the next time you wash it, the stuff comes right off with another wash. If you have stuff you cant get off, then you can use a tiny bit of joy in spots and wax in place. Keep the joy small cause it strips wax off. Thats what i am doing and what was recommended from the shop. Of course their first answer was to buy the spray on wash they have.... but then i talked to the sales guy, and he says bs... just use car wash with wax as i have told you. Just dont use paper towels on the seat.... that will leave a paper residue on it and you will have to use a brush to get it out.
I've got to comment on the advantages of a pressure washer at times.
chain cleaning.
Once the rear tire is lifted you can spin the chain just from water pressure directed at the sprocket. A steady stream of warm water on the chain takes off ANY gritty nasties that might cling on under normal washing. It really makes cleaning my chain every few days enjoyable(ok, no sexual enuendos).
-Dean
Kerosene (or lamp oil, same thing) and a toothbrush for the chain and sprockets. Kerosene and a rag for the wheels. Everthing else Simple Green followed by a rinse with the nozzle set on "shower". Wipe down with a towel. Any good automotive wax for the painted bits, Vinyl Life for the rubber bits.
To clean all the nooks and crannies it helps to have a couple of wood dowels, maybe 1/4", and some disposable shop towels (the blue paper ones).
1 - 20 of 30 Posts
