1 - 14 of 14 Posts
Hey, I'm going to a 16 tooth front sprocket for highway use now that the gf is 3.5 hours away at university. Is it OK to use a front sprocket without the rubber sides on it like the OEM sprocket? I'm pretty sure it's OK but I just want to check.
yes, it may make some noise but it's fine. My 14 tooth has no rubber on it and it's been fine for a few thousand miles now...
Ding! thanks! I'mma be out in the garage to chuck it on there.
I tried going to a 16 tooth front a while back and didn't like it at all. I installed it before I went on a longer trip to see how much of a difference it would make in milage cruising (for the Californians on here, I live in Oakland and rode to San Louis Obispo and back).
Frankly, I found that while it was O.K. for long trips, it really took all the fun out of the bike around town. No get up and go to speak of. I enjoy a smaller bike as much as anyone, but the SV is heavy enough that without the extra accelleration, it was just lame. That said, I usually run a 14 tooth sprocket up front, so I might be expecting too much from the larger sprocket.
That is kinda what I figured. I run a 15 front and a 46 rear. I like the extra torque and I'll put up with a little higher RPMs to get it. But, this is America and you can do what you want! I'm sure there are those out there who love the taller gearing!
What is stock gearing for our SV1000's? 17/40? Anybody know of a 520 conversion set? Thanks...
you can get a 16t with the rubber thingie.... stock gsxr 16t fronts fit the SV
I am running 16/46 first I went to 16/45, but it took a bit more zip awy than I liked so i went up 1 in back too, I like it, I cruise 80mph @ 5000 rpm and don't have to shift as much
How?  If you have a 17 up front and go -1 to a 16 it makes it accelerate more quickly.  Makes the lower tq more useable...
Just figured out you had a 650... the 1000 is 17/40... guess i should read the sig lines better... ;D
??? I thought SVs were 15 stock up front!
whats a 2nd gen naked front and rear??
For the record the only urgent sprocket issue is when your thumb is stuck between the sprocket and the chain!
1 - 14 of 14 Posts
