1 - 9 of 9 Posts
ron ayers is showing different part numbers for the upper cowl for the 650s and the 1k. i can't figure why they'd be different except for the stickers.
would the 1k fit on the 6-fiddy? on the same fairing stay? or would i need a 1k stay?
I know a kid that wrecked his copper 2003 sv650s and replaced the fairing with a sv1000 2003 copper fairing. Should work, if it worked for him. Maybe the reason its a different part number is because of the sticker (sv650 or sv1000)?
i found a local seller selling 03 sv1000s lower fairings for cheap. THe problem is I got an 03 sv650s. Would this be a problem? Can an 03 sv1000s lower fairing fit on an 03 sv650s??
Any info is greatly appreciated.
1000 & 650 fairings are compatible
stranger said:
nose cowls or full fairings? i thought the 1ks were wider and thus wouldn't fit the 650
Not 100% sure but I'd have to agree its the upper fairing that is compatiable. The lowers shouldn't be. They do have different part numbers too.
yeah just the uppers as far as I know
that's what i thought. but monz took your answer as the lowers are interchangable, which i was pretty sure wasn't the case
1 - 9 of 9 Posts
