Any advice? Worth it or not?
Noticeable sound difference over the stock pipe with slipon?
second gen cam swap.ya, I've looked all over for cams but short of custom ground, 700 dollar cams, I haven't found anything.
yes easy 4-5 hp2nd gen exhaust cams put in the Intake side, intake cams moved to exhaust, couple of new gaskets- under $200
There's a good thread on it in the FAQ section.
Hey man how hard would it be to swap the cams just as easy as changin them or what and how much porwer will this give you with a slip-on and a knn filter and were will the power be like mid range or high oh and what would you need to jet the carbs to like a stage 2 jetting or what2nd gen exhaust cams put in the Intake side, intake cams moved to exhaust, couple of new gaskets- under $200
Oh thanks man yeh i wrote that in a hurry lol.I think what he's trying to say is.....
1) How involved is the swap? How dirty do my hands have to get??
2) How much time it would take?
3) How much of a power increase can i expect with a slipon and K&N filter?
4) Which areas of the powerband will increase? And which will decrease?
5) What kind of jetting would you guys reccomend for these mods??
I rephrased your question cause i hate run-on sentances, and i also have the same questions.![]()
It is actually 2nd gen INTAKE cams on intake side, 1st gen INTAKE moved to exhaust side.2nd gen exhaust cams put in the Intake side, intake cams moved to exhaust, couple of new gaskets- under $200
I was closeIt is actually 2nd gen INTAKE cams on intake side, 1st gen INTAKE moved to exhaust side.
ac
If only cam swapping was horseshoes or hand grenades you'd be golden! LOL!I was close![]()
