The manual says to set idle at 1250, but personally I like it a little higher
adjust the idle with a screwdriver through the left side frame of the bike, just under the gas tank. The screw should have a white plastic backing to hold it in place
I'm honestly surprised you can hear the fuel pump running - my engine/exhaust is far too loud to hear the little fuel pump..
I reallllly hope this is a joke...
if not.. Adjust the idle when its warm.. easy to do
its fuel injected... no way to pump fuel from a tank with out a pump running while the bike is running...
i have three sv's sitting in my garage, this is the only one that you can hear the fuel pump, over the motor and exhaust. its also the one with the highest mileage. so I wasn't sure if it was a sign that the fuel pump is on its way out.
and apparently someone at the local bike meet thought it would be fun to turn my idle screw up. It was all of the sudden yesterday and a big difference that's why I was concerned.
