what is the best way to mount aftermarket turn signals into the stock ~ 2x1" hole. I'm thinking of using sheet metal to make a plate to fit over the hole. Is there anything aftermarket i can buy to fit this hole?
Also is the stock signal relay solid state. i'm planning on putting LEDs on. the relay does not click when the signals flash so i'm guessing it is?
btw i have an 08 sv650
http://cgi.ebay.com/ebaymotors/FLUS...orcyclesQ5fPartsQ5fAccessories#ht_2898wt_1420
These from ebay fit perfectly into the stock signal holes. I also bought some amber bulbs for the parking lights and wired those in with the turn signals as these aren't too visible from the front.
These will flash fast, so if you want to normalize the flash rate you need to buy a flash rate controller, or just wire one 10W, 10ohm resistor in parallel with each turn signal.
