1 - 2 of 2 Posts
Can someone please post a video of there bike with there turn singals on my turn signals are blinking really fast thaey all are working but just blinkingreally fast. Thank you
If your turn signals are blinking fast it is most likely because you have LED turn signals and your stock turn signal flasher relay needs to be changed from a thermal relay to an electric flasher relay.
Some thing like this will eliminate your problem.
The stock signal flasher work off resistance, when you use LED blinkers the resistance changes. Electronic flasher relays will not change flash rate with the different resistance levels.
1 - 2 of 2 Posts
