1 - 20 of 25 Posts
I know the LED flasher relay topic has been thoroughly explored, but I have come up with nothing using the search on anything TST industries. I see they make a plug and play LED flasher relay:
http://tstindustries.com/product.php?productid=17557&cat=268&page=1
Is there anyone out there using this relay or any similar type of plug and play led flasher relay fix? And before you say "WHY DONT YOU DO THIS INSTEAD", let's just remember to stay on topic, I know where to find other relay info. Thanks guys.
That is a nice plug-n-play solution. No mucking around with load resistors.
You can save a few buck by crimping in an off the shelf electronic flasher, but for $24.50, easy clean install, I'd buy it. :thumbsup:
:eek:ccasion14:
Thank's for the input
There's some even cheaper ones on ebay for about $10 less I may try out also.
I agree with Tee, I had mine wired with a normal car flasher at first but it was always in the way and got damaged in a wreck. I upgraded to a plug-n-play unit and it is much cleaner. Especially now that you can get the plug-n-plays for about the same price as rigging up a standard auto flasher.
TST or some no-name brand/ebay unit?
I put velcro on my module and my rear frame...stuck it in one place and it hasn't moved a bit. PNP is much easier, but at half the price, I'm happy with the electronic flasher module I have.
It was some no name brad, works fine though.
The electronic flasher is what I did the first time for the same exact reason it was half the price. ~$10 for the relay and a couple bucks for the connectors so I didn't have to cut my stock wire harness. The PNP are much cheaper now, I got mine for around $16 shipped, they sold for $40 when I did the first relay mod.
Alright, so I bought the cheap no-name Chinese unit off of ebay for about $17. Got it in the mail, put in in the bike. The flasher timing was right, but when the signals illuminate, the bulbs are dim and flicker, along with a quick flicker when they first illuminate. Needless to say I was not happy.
I got my money back and decided to spend $24.95 on the TST unit. Got it in the mail quickly in a nice box with bubble wrap (instead of an envelope) and a cool TST catalog (with a SV race bike on the front!). The relay itself has the TST logo part of the top cover, separating itself from the cheap Chinese units. Plugged it in, tested it, and all I can say is wow this thing is the real deal. Works like like the stock flasher, a real solution to LED signals. Lights are bright, no flicker, timing is perfect. Buy this relay!
They worked my Rizomas, but the indicators on the panel do a weird fade-out for the side that's flashing, but the signals themselves work fine. Adding a resistor to either side fixes it, but It's not really bothersome so I keep the resistors off.
@Slono @Arudinne Any updates??
I installed 3/4 Rizoma Turn 11 Signals last night with resistors and they are currently blinking fast. I don't like the idea of having resistors on the bike which are going to heat up, so I'm looking at this solution or just wiring up an electronic 2/3-pin one from Autozone.
1 - 20 of 25 Posts
