I stayed over at the GF's last night so I parked my bike outside. It was roughly 23-24* this morning when I went to start the bike. It turned over twice, fired several times and died. It isn't the first time that's happened but it hasn't happened more than 10 times since I bought the bike new. The odd part is that it would turn over on each subsequent try, sound like it wanted to fire but it never took. I tried about 5 times and then gave it some throttle to encourage it. When I did that, everything on the gauges went blank (back light still on) and when I let go of the starter and throttle the fuel pump primes and the gauges flipped on like I had just turned the key. I'm wondering if the TPS has something to do with that.
After about the 7th try I got the bike to start and I blipped the throttle just to make sure it wasn't yanking my chain. I let it warm up for a minute (I usually just get on and go) and noticed that there was quite a bit of water coming out of the exhaust; enough to puddle on the exhaust tip and to leave a spray on the ground. I never made note of something like that before.
I'm not worried since this is a first and probably won't be a recurring issue. I'm overdue for changing the plugs (15,000+ miles) and that will be done with trying to pach the radiator in the next few days. Just a bit curious is all.
