1 - 9 of 9 Posts
· Registered
My old bike had clip on bars and they were super comfy. Currently my 2001SV has dirtbike bars and risers which I find my position to be not as agressive as I'd like. Therefore I bought a stock set of clip on bars for my SV (Stock because I like the stock look). Now I am having trouble finding the triple clamp that came with fork mount bars.... anyone have an extra or know where I could get one? My current bars are off and I'd be up for trade or anything...I'm desperate... :confused:
· Registered
FYI, some think that you actually need the top AND BOTTOM clamps as the angle is slightly different between "S" and "N". I don't myself have an opinion.
· Premium Member
You can make the S clip ons fit your existing top triple. There are past posts that can indirectly give you all the info you need like: cut/shortened headlight brackets or 4 exhaust type clamps to use as your headlight fork brackets, installing the S clip ons in a lower position so they can be fitted to a naked top triple. Look up S to Naked conversion, or clip ons and see what shows up.
tk
· Registered
I don't think that's accurate. We installed a naked lower triple on fatass' bike 2-3 years ago and used his stock SVS top triple with absolutely no issues.
All accurate. Like I said, "some" believe it to be the case. The part numbers are most assuredly different both with gen1 and gen2. Many people manage to get them swapped; all have said that the replacement was a "tighter" fit then the original. Again, I have no opinion on this and don't know if it would make any difference one way or another.
1 - 9 of 9 Posts
