1 - 8 of 8 Posts
My bike won't start! I just got the battery recharged about a month ago. Everything was okay. I tried to start the bike today... nothing. No clicks or anything. Weird thing is that gauges, lights, and turn signals all work. Any idea what happened?
Thanks in advance,
Mark
how about your kill swith :p
what is the voltage of your battery is it dead again, have you been riding the bike regularly?
Also check to make sure the connectors for the clutch and kickstand connectors haven't worked themselves loose. That would cause the symptoms you describe, IIRC.
I'm with e lo.
Had the same problem a few weeks ago. Turned out to be the clutch safety switch. Pull the connector off at the clutch lever, use a small piece of wire to jump the two wires in the connector and complete the circuit. If it starts it's the clutch switch. The contact was a little dirty on mine. Cleaned it up and was good to go.
1 - 8 of 8 Posts
